1 - 14 of 14 Posts
Idk what Im talking about
250-amp alternator from Motor City Reman (www.motorcityreman.com)
'250-amp' (clamped 90-amps out of it at idle, probably could do more though)
It's a large-case GM meant for a suburban but will fit others, not certain on which ones tbh
It has been in the saturn for years now but wasn't used all of the time, it actually probably only saw a little under a year of true use. It's in working order just looks old because it's been under the hood for a while now. There's a bit of corrosion on the pulley but that could probably be pretty easily cleaned off. I was running it with only the power wire as a turn-on since I already had an alternator that my car controlled...it held good voltage - around 14.6-14.8v
110 shipped
You can see it in my AC-position...
Again, in the background...
Yep, on their site it was sold as a suburban's alt when I bought it but will fit many GM vehicles.
NOT LOUDER THAN YOU :(
if it has the round 4 pin plug it will fit ALOT of vehicles. my 2001 blazer has the 4 pin and this will fit perfect. i believe most gm vehicles from 96 and up take that plug.
I'm honestly not certain, I'll have to look into exactly what vehicles it fits.
Thanks, bobbarker ;) :)
SOLD...thanks, man :) :D
1 - 14 of 14 Posts
