[SOLD]Fs pair of tb ultra 8s
962 Views 12 Replies 5 Participants Last post by  kn0wledge000
I BELEIVE 400 RMS?? dual 2 ohm and beleive 30hz fs
excellent condition. purchased from audiophil and they did what i wanted! sound great and get low for some 8s. very clean sounding. 12ga wire soldered on for direct leads
175 shipped to your door insured
1 - 13 of 13 Posts
Long shot, but you wouldn't happen to have gaskets for these do you? I'm looking for one for an 8 I am building and using a TB Ultra basket.
I don't think I got them with subs. Ill look tomorow. But doubt it as I would have used them
That's kind of what I figured, since they weren't in the picture of them installed.
TB's dont come stock with gaskets
Ahh ok, know of any that fit offhand? The one from my 8" 12 spoke basket is too small.
Crystal mobile sound CMP 8 will fit but different hole pattern. Treo SSi 8 gasket should as well.
TSP's from these drivers
(nearly identical (still needed break-in when pulled)
Re = 3.5805 ohms
Fs = 41.1098 Hz
Zmax = 48.6163 ohms
Qes = 0.4063
Qms = 5.1107
Qts = 0.3764
Le = 2.2468 mH (at 1 kHz)
Diam = 155.5750 mm ( 6.1250 in )
Sd =19009.4467 mm^2( 29.4647 in^2)
Vas = 7.5805 L ( 0.2677 ft^3)
BL = 15.1995 N/A
Mms = 101.4981 g
Cms = 147.6697 uM/N
Kms = 6771.8691 N/M
Rms = 5.1298 R mechanical
Efficiency = 0.1218 %
Sensitivity= 82.8742 dB @1W/1m
Hx2 or he may work also. I'm feeln frisky. 175 shpped!
Take the off topic to PM's please.
Sorry about that, will do.
And thanks Phill!
up
come on guys these things sound like s.e.x in his burban little box big boom
Sold and traded to mr BOBBARKER!
1 - 13 of 13 Posts
