2
MA AUDIO 589I
High Performance 2-Channel Class AB Car Amplifier
RMS Power Rating:
- 4 ohms: 150 watts x 2 chan.
- 2 ohms: 220 watts x 2 chan.
- Bridged, 4 ohms: 300 watts x 1 chan.
Max power output: 600 watts
Pulse Width Modulated MOSFET power supply
LED power (green) and protect (red) indicators
Bass Boost/EQ details (0 to +18 dB bass boost at 45 Hz)
Soft Start Turn-on
2/1 Channel operation
Speaker-level inputs with signal sensing for automatic turn-on
Preamp RCA outputs to daisy chain multiple amps
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Dual speaker terminals simplify the hookup of multiple speakers
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Silver-plated RCA level inputs
Silver-plated screw terminals
Input sensitivity:
Variable high-pass filter (50-250 Hz, 24 dB/octave)
Variable low-pass filter (50-250 Hz, 24 dB/octave)
Channel Separation: 60dB
Frequency response: 20-20,000 Hz
Dimensions: 9-1/8"
L x 9-5/8"
W x 2"
H
1 MA AUDIO 589I AMP BRAND NEW IN BOX NEVER OPENED.
50.00 + s&h
