1 - 16 of 16 Posts
Item(s) for Sale:
Mmats Juggernaut 15 Motor and basket
I'm pretty sure the motor is shared with an older DD 9500 series, B or C maybe. If someone knows for sure please chime in and let us know.
Item(s) Description/Condition:
I picked up this blown juggy 15 today. It WAS a dual 2ohm but there's a fried coil and a bad tensile on the other side.
Motor is in overall good condition. Slugs are aligned, no cracks, no major chips beyond typical wear miniscule chip off a corner....barely noticable and wont effect anything. There's some glue leftover where the basket screws down but a razor will take that off easily.
The basket....I accidentally stripped the head of one of the screws for the basket (used the wrong drill bit like a dumb ****). So i was going to break the bolt by twisting the basket and sure enough the that one spot on the basket broke instead of the bolt. That being said the bolt came out of the motor fine, no damage to the motor whatso ever, and the basket has that one (of six) bolt spots gone. The good news is you can still use the basket on this motor (or others) without issue as the mmats motor only uses 3 holes on the motor, and with the 6 holes on the basket it can be lined up to utilize all 3 mounting holes. even though that bolting spot is broken off the brest of the surrounding basket bolt mount area seems uneffected and plenty sturdy. It was just alot of pressure at that one angle that broke that small section off.
The original cone and dustcap are still in good chape and I can throw if for free if requested to the first buyer. Also to the buyer of the motor i can include the original blown VC so you have a something to go off of to get another fitting coil. It's a 3in or just barely over 3in coil.
Price:
Motor alone - $100+ ship (usps large flat rate shippd and insured to your door for $117.50)
Basket alone - $10+ ship
Motor + Basket - $150 shipped (being so large and heavy this price hike goes stright into covering shipping expenses).
NO TRADES and prices are pretty sure as they are already cheap for quality gear.
Shipping and Miscellaneous Item Information:
Fedex Ground or USPS Parcel Post/Flat Rate
Item Pictures:
here you can see the basket lined up to fit perfectly with the motor's 3 mounting holes even though there's a chunk missing.
cone and dustcap before cutting the surround/spider:
Ref's: Years of selling on ca.com. You're in good hands.
Check out my iTrader on ca.com and diyma:
http://www.caraudio.com/forums/itrader.php?u=19832
http://www.diymobileaudio.com/forum/itrader.php?u=29218
PM me with any questions
Hockey players, man...
old schooly.
DD made that motor.
so i emailed mmats.........
We do not give this information out, sorry.
Best regards,
David Thompson
President
MMATSPROFESSIONAL AUDIO
(561) 842-0600ph.
(561) 840-1405 fax
www.mmatsproaudio.com
Sent: Friday, February 18, 2011 5:10 PM
To: [email protected]
Subject: Voice coil/motor gap size on a juggernaut motor?
any idea what the gap specs are for the juggernaut motor?
more specifically the one in this forum thread?
http://www.caraudioclassifieds.org/forum/showthread.php?p=1083579#post1083579
Thanks for the info,
Jay
Soooooo.....
if anyone knows specifically what DD 9500 motor this is similiar to plz post up here so we can track down some gap specs. I'm rather suprised Mmats doesnt give that info out.
got the same one.. where in fl are you?
let me find the gap dimensions i think i wrote them on the motor itself
2.98 and 3.25... it's a mmats motor i believe the dd is exactly the same but has dd on back... i was looking for another for a while, they also made this motor with a large gap for a quad VC woofer, which is what all the other ones i found were
it's a pretty heavy motor too... just short coil height, i didn't figure it was going to make a good daily low tuned sub
thanks for the info. that coil in your pic looks identical to the one i pulled out of mine, and using a regular tape measure it appears to be dead on to what you listed. I'm pretty sure those measurements are correct.
1 - 16 of 16 Posts
