(Thermal/Over Current/Speaker Short/Speaker DC Protection)
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Zero(0) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~18V
Digital Class-D Linkable Mono Block Amplifier
1 Ohm Stability
RCA Line Input and Master Output
24dB Octave Crossover Slope
Wired Remote Controller
MSRP $799 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH ----RMS power, 1 ohm mono
1500W x 1CH ----RMS power, 2 ohm mono 800W x 1CH ----RMS power, 4 ohm mono
400W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm <0.1% Efficiency @ 4 ohm 86% Fuse rating 40A x 4 Input Sensitivity 200mV to 6V (+/- 5%) Dimensions 252(W) x 58(H) x 434(L)mm
3. Description/Condition: B Stock purely cosmetic...works 100%
4. Price: :$245 Shipped CONUS
** DO NOT DELETE ANYTHING BELOW THIS LINE OR THREAD WILL BE DELETED ** -----------------------------------------------
Thank you for your interest in CarAudioClassifieds.org. A forum community dedicated to Automotive Audio enthusiasts. Come join the discussion about builds, modifications, troubleshooting, models, styles, reviews, classifieds, and more!
