Mach5 Audio MJ-18
T/S Parameters
Fs = 24 Hz
Re = 3.6 Ohms
Qes = 0.37
Qms = 5.59
Qts = 0.36
Mms = 316.6 g
Rms = 8.5 kg/s
Cms = 0.14 mm/N
VAS = 210 litres
Sd = 1029.2 cm2
BL = 21.3
Xmax = 15 mm
700w RMS
SVC4
Only has been used for 3 weeks, looks new. Will ship in the original Mach5 box.
Suggested box size:
3 Cu ft Sealed
5 Fu ft @ 30hz ported (was suggested I could go down to 4.5 cu ft)
4. What you are looking for: :
TC sounds TC-9 motor(similar motors considered) + Cash
5. Pictures of your item for trade:
Vid:
YouTube - Mach5 Audio MJ-18
Plenty of refs on CA.com, Screen name is the same.
Mach5 Audio MJ-18
T/S Parameters
Fs = 24 Hz
Re = 3.6 Ohms
Qes = 0.37
Qms = 5.59
Qts = 0.36
Mms = 316.6 g
Rms = 8.5 kg/s
Cms = 0.14 mm/N
VAS = 210 litres
Sd = 1029.2 cm2
BL = 21.3
Xmax = 15 mm
700w RMS
SVC4
Suggested box size:
3 Cu ft Sealed
Vid:
