1 - 11 of 11 Posts
Sound stream human reign
HRU.4
RMS Power Rating:
4 ohms: 140 watts x 4 chan.
2 ohms: 240 watts x 4 chan.
Bridged, 4 ohms: 480 watts x 2 chan.
MOSFET power supply
LED power and protection indicators
Hawkins Bass Boost (0-9 dB @ 70 Hz)
STACT (Stabilized Apex Current Technology) reduces power supply stress by 50%
4-Channel operation
IDI (Intelligent Distress Indicator) provides visual indication of amplifier protection status
RUBI (Rapid-Use Branched Impulse) proprietary power supply technology
Preamp RCA outputs
Harmonic bass alignment for a cleaner and sharp bass equalization
Triple darlington output circuitry
Drive delay II eliminates turn on/off pops
4-Way protection circuitry (DC, thermal, short, and impedance)
Selectable balanced inputs for enhanced level of noise reduction
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Variable high-pass filter (50-500 Hz, 12 dB/octave)
Variable low-pass filter (40-160 Hz, 24 dB/octave)
Subsonic Filter (13-30 Hz, 12 dB/octave)
Frequency response: 10-40,000 Hz
THD (Total Harmonic Distortion): 0.005%
Signal-to-noise ratio: 105dB
Dimensions: 22-1/8"L x 11-1/8"W x 2-3/4H
4-gauge power and ground wiring is required for installation.
Open to all trades
Sent from my iPhone using Tapatalk
1 - 11 of 11 Posts
