When I play a song that doesn’t start out with much bass, take for example Kissland (The Weeknd), the beginning has some bass, but not enough to really go to the subs, mostly just mids. Then, further into the song, the lower bass frequencies appear on the song and seem to activate the subs and it sounds as if someone suddenly turned the gain up and I have to use the remote knob to lower the bass.
Sometimes, when I play a song with little bass and switch to a song with a lot of bass, it’s as if they suddenly turn on and the bass increases WAY more than it should.
I have an Lc7i from stock Gmc Yukon head unit to both amps via RCA (All preamp output knobs are turned all the way down). Skar 1500.1D powering two 12” Compvr’s Skar 75.4AB powering a pair of Kicker Coax for rear doors, and Kicker Component set for the front.
It’s annoying, unpredictable and I don’t want to be bumping to loud music, then have a pair of subs blown. Any help/suggestions would be appreciated, thanks. https://omegle.onl/ vshare
