1 - 1 of 1 Posts
I'm using the factory deck (not the sony) 13 ford taurus and the lc8i for the rca. I have 2 twisted sound 1.8kw amps that I can use or just 1and 2 sundown sa12 2ohm subs. The lc8i can handle 800w per channel. The amps
Whats the best way to get the max wattage out of the 2 subs in a ported box. I also have a 2nd battery that is installed so I can have 12v continuous power. I'm using 0g wire with 250amp fuses. I was thinking of hooking 1 sub to 1 amp each wired to 1 ohm. Any help would be greatly appreciated. Thanks
1 - 1 of 1 Posts
