1 - 12 of 12 Posts
Walking TSP Encyclopedia
VooDoo Warrior VW15.2D
Re = 4.2046 ohms
Fs = 27.1756 Hz
Pe = 2000w RMS
Zmax = 74.1004 ohms
Qes = 0.5618
Qms = 9.3397
Qts = 0.5300
Le = 5.1620 mH (at 1 kHz)
Diam = 310.0000 mm ( 12.2047 in )
Sd =75476.7656 mm^2(116.9892 in^2)
Vas = 63.2820 L ( 2.2348 ft^3)
BL = 23.6747 N/A
Mms = 438.6239 g
Cms = 78.1968 uM/N
Kms =12788.2451 N/M
Rms = 8.0190 R mechanical
Efficiency = 0.2124 %
Sensitivity= 85.2896 dB @1W/1m
Xmax 16mm (One Way)
Weight = 44lbs
Brand New, only hooked up to pull specs and tested coil alignment. 3" 4 Layer Coil
$180 Shipped Con-US
looks like its the same as a crystal mobile sound cmp.probally a low end monster!
Nice call John, Im impressed, it is the same soft parts, and its an SQ Monster, flat as can be, a very over looked woofer with great capabilities!
lol why would you doubt me...is it also underhung?the one (cmp12) i just sold looked just like that except my motor looked very atomic or ed.
edit: you going to bring me that TB ultra 8 this week?
Will be over tuesday,
I dont recognize the motor one the VooDoo, double stack 1" slugs and 1" or better top-plate. Overhung design though, clearance wise the sub should do 2.5" P-P without mechanical damage.
Up, dont think this is a generic sub, its a badda** in disguise, 20Hz easy and flat as a flitter that low means crazy gains if tuned higher people who want it louder!
I've seen a few of these floating around lately here on CAC and on eBay. For being so inexpensive, they look extremely solid and pretty beefy on the motor structure. I remember the first time I saw one these I though to myself "These will probably be the next Konaki's" :)
Discussion Starter · #9 · (Edited)
Apples and Oarnges.
Lol, if the company didn't go out of buisness in like 04, they wouldnt be so inexpensive lol. They used way better components & R&D than Konaki, lol. And in fact, it's kinda an insult to even compare the level of engineering in these to the mass market parts assembled to be called konaki. A generic cone, widely available Y20 motor and left over spider packs compared to Crystal Mobile Sound CMP softparts and double stacked 1" Y25 Slugs with 1" Top-Plate. Not only will the VooDoo play lower and flatter with way lower THD than the konaki crap, it will not color the sound with retchid 2nd and 3rd order decay. lol. Apples and Oarnges my friend, and its because of me getting on the Guy on ebay with the 15's that their listed again, the 12 on here is insanely overpriced and used. Konaki, lol, thats funny. The use of that word should be instantly considered post dumping, lol. You'll see no junk like that listed by me, lol. I'd even take the Mobile Dynamics version of that woofer over a konaki version, lol.
[Traded]
It is in deed, tristan has it now over on CA.com
1 - 12 of 12 Posts
