VooDoo Warrior VW15.2D
Re = 4.2046 ohms
Fs = 27.1756 Hz
Pe = 2000w RMS
Zmax = 74.1004 ohms
Qes = 0.5618
Qms = 9.3397
Qts = 0.5300
Le = 5.1620 mH (at 1 kHz)
Diam = 310.0000 mm ( 12.2047 in )
Sd =75476.7656 mm^2(116.9892 in^2)
Vas = 63.2820 L ( 2.2348 ft^3)
BL = 23.6747 N/A
Mms = 438.6239 g
Cms = 78.1968 uM/N
Kms =12788.2451 N/M
Rms = 8.0190 R mechanical
Efficiency = 0.2124 %
Sensitivity= 85.2896 dB @1W/1m
Xmax 16mm (One Way)
Weight = 44lbs
Brand New, only hooked up to pull specs and tested coil alignment. 3" 4 Layer Coil
$180 Shipped Con-US
Re = 4.2046 ohms
Fs = 27.1756 Hz
Pe = 2000w RMS
Zmax = 74.1004 ohms
Qes = 0.5618
Qms = 9.3397
Qts = 0.5300
BL = 23.6747 N/A
Mms = 438.6239 g
Cms = 78.1968 uM/N
Kms =12788.2451 N/M
Xmax 16mm (One Way)
Weight = 44lbs
$180 Shipped Con-US
