1 - 13 of 13 Posts
http://www.woofersetc.com/p-5357-md-21-us-amps-2-ch-md-series-amplifier.aspx
the above link shows a md21. will this amp be ok to run 4-6.5's 4-tweeters and 2 bullet horns. im currently running it all on my avh-p4200 and it sounds great until the bass drops. will this amp be alot better and be able to keep up with the bass. i dont really wanna drop alot of money on a frontstage amp. i found this amp pretty cheap and it will match up nicely to this md1d that im getting.
is strung out on QUAD
it should do the job its goin on hights and its stouter than the speaker output on the radio. give it a try u jus might love it... im a US Amps fan...
http://www.betherave.com
I'm gonna assume you're using 2 passive crossovers. Each one going to (2) 6.5's (2) tweets and (1) bullet horn.
Thats way too much speaker for 15-18 RMS watts to move properly.
First thing I would do is check what your final impedance is going to be @ the amplifier. You can do this with a multimeter.
Let me know what impedance (ohms) you end up with and I can help you find an amp that will compliment your setup nicely. Also, what speakers are you using or what is their power handling? (watts rms)
I don't know if you already have a subwoofer in the car but when you add an amp you are going to need to buy an amp kit which has power and ground cable, RCA interconnects, remote turn-on wire and of course speaker wire. :thumbsup:
Edit: Just saw your sig so ignore the last part
I would talk to boomsday about the md42 because it's a nicer amp and puts out more power.
With all of those tweets and speakers hooked up to one crossover your not going to have a 4 ohm load. IDK what its going to end up @ but your best bet is to check what impedance you are getting at the point of the crossover with a multimeter. It's really easy to do
75 watts will push those speakers and help with midbass response BUT I would try to get something that does around 150 watts so you have some headroom and don't clip.
i agree with you about the higher wattage more headroom :thumbsup:
thanks, for the info. and yeah i will be using a multimeter to check the final ohm load......on another note, i was just looking at the powerbass components http://www.powerbassusa.com/3xl-series-1 and the coaxials http://www.powerbassusa.com/autosound-series-drivers what your opinions?
I can't speak on how they sound because I haven't heard them but they look nice. I like that they have neo mags, swiveling tweets and are 3 ohms so you can get a little more juice outta your amp
there main warehouse is right by my house. i went for a tour there. saw these and i was impressed... would be a great buy
cool thanks, whenever i get some extra cash i will be buying some better front stage and these might be the ones i get.
i will probably get my boy twistedchild420 to help me with some pics and vids.
1 - 13 of 13 Posts
