1 - 20 of 53 Posts
i have a 15" vfl and got offered a 15" xfl and i was wondering which 1 is better and y
The vfl is a bigger power handling woofer heavier magnet and so on
In order of price from high to low vfl hd xfl
Smart dude :D listen to him (since he's an AB dealer)
Ja Marcus
Yes the VFL is the top of the line competition sub. The HD is the next level down. I think the XFL is a more musical sub then the other two. But not worth an even up trade.
ok guys thanks for the input i always get em confused and any box reccomendations for the vfl
mine is the vfl extreme does that make a difference
The VFL is built by SJA Industries and it is the same as an Atomic APX (or APXX) depending if it is the extreme or competition. Either way any VFL is U.S. made with better parts and can take a ton more abuse over the Chinese made HD or XFL. The HD and XFL are good subs BUT, they are built to have a good price over power handling and abuse. The VFL has a larger (better made) coil with much more motor force and much stiffer suspension. The XFL has a Chinese coil, a motor with less motor force and Chinese spiders that will not handle as much power.
Errday I'm Hustlin'
If its like my VFLs its an Atomic 818 motor
Discussion Starter · #9 ·
jus to clarify it is th extreme so what diff does that make if any
wowo American bass has 2 vfl model subwoofers the V1 and V2. The V1 is rated at 750rms the V2 is ??????rms (aka the 818 motor). as for American bass line up of woofers it is as follows by rms SL,DX,XO,SQ,XD,TNT,VFLV1,XFL,HD,VFLV2,Full Custom!
To the OP, If its the VFL comp with the 818 motor it will smoke the XFL, The 818 motor is worth almost as much as the whole xfl! If its the V1 vfl then it would be alittle upgrade to go with the XFL. Do not get me wrong the XFL subs are a under rated beast but not in comparison to the true VFL!
getting ready to post a pic so u guys can help me out
Ja Marcus
I thought the extreme was the 818 motor.
Ja Marcus
Looks like the 818
Discussion Starter · #17 ·
ok so i should hold on to it lol and it has the lil holes in the bottom jus like atomics do
Ja Marcus
If it has the holes in the back plate around the pole vent then I'm pretty sure thats the same as the 818 motor.
Discussion Starter · #20 ·
putting up 1 more pic
1 - 20 of 53 Posts
