what exactly to look for in a car audio battery?
415 Views 4 Replies 5 Participants Last post by  tymoto21
What to Look for in a Car audio battery? I really would like to know what all the reserve capacity ratings, cranking amps and ah mean, and how they technically relate for car audio purposes​
1 - 5 of 5 Posts
from what im gathering and im new to this.A shuriken sk-bt80 is 80Ah and 1900CA which is supposed to be good for bout 1800 watts or so. dont quote me on it tho. jus like a shuriken sk-bt120 is a 120 Ah 2600CA batt and its good for 2400 watts according to SHURIKEN >> http://shurikenonline.com/products.html <<
CCA and CA don't really play a roll in car audio so much. You want to look at reserve capacity and ESR or internal resistance for starters.
Internal resistance, discharge voltage
^yes
a low internal resistance, and you want alot of ah
that is the rating for how many amps you can run for 1 hour before you get below iirc 10.4v (either way its around that and you dont want it to be that low anyhow)
1 - 5 of 5 Posts
