1 - 2 of 2 Posts
Tinder Douchebag
2010 hhr - Stock alt - 4awg stock copper - 650cca lead acid - second 650cca lead acid via forklift style 1/0 quick disconnect - 150a anl - s1500.1 - no fuse on s800.4
Where should I add fuses? And what amperage? Can I put a 120 on the 1500?
As close to the battery positive terminal as possible, a circuit breaker at each battery, then fuses before each amplifier. Check with the manufactures instruction manual amperage recommendations are for the fuses.
1 - 2 of 2 Posts
