1 - 15 of 15 Posts
NOT LOUDER THAN YOU :(
bestbuy.com has them for the low!
Someone said they were the best prefab you could buy. Make your own. I'll be worth it and you'll pat yourself on the back for accomplishing something.
Hockey players, man...
Look on ebay that same kit is cheaper there. It's a good kit for what it is. I've used it a couple of times for lower powered installs. You can't buy all of the fuses, fuse blocks, and ground blocks for that price at most shops and the quality on the fuse holders is the same as most stinger stuff. That'smainly whay I buy it, for the parts. RCA's are cheap, but they work. If you're on a budget it will do. What are you planning on running with it? The actual gauge size (they say) is "true" 1/0ga. Most car audio wire is bigger in the same size. The 4ga in the kit however, that is a joke. I've never actually used it for anything. Again, it is what it is. The ones I have used were ofc and not cca if that matters. Not sure if they all are though.
is strung out on QUAD
a set of punch amps a p1000.1 on sub and a punch p400.4 on mids and highs.
wat about knu konceptz wire is it any good?
1 - 15 of 15 Posts
