1 - 4 of 4 Posts
lol... find a bolt take it off sand ne paint where is is then stick the ring terminal on there then put the bolt back on
Make sure it's a solid piece of metal, a bolt for a seat is good because they are mounted very solid. Also a voltage check once you make the connection is a good way to see if its a good place for a ground ;)
1 - 4 of 4 Posts
