nokturnal...are you from the nokturnal carclub/ expensive taste?
thanks!!!!!higher the strand count = less resistance and more flexibility...go with the highest strand count you can find
Something like this would be good...665 strand count --> Robot MarketPlace - 8 gauge high-strand count wire - Red
This would also be good...same strand count, OFC copper --> http://www.woofersetc.com/p-6483-spw18t-stinger-pro-8-gauge-premium-power-cable.aspx
This one appears to be the best...805 strand count, OFC copper --> Knukonceptz product detail for KARMA SS 8 GAUGE SPEAKER WIRE
No problem! :hello: That Knu-Karma looks nice, but $1.65/ftthanks!!!!!
What if his subs have direct 8awg leads? :dontknow: Some banana plugs also accept 8ga conductors so you could go that route as well.Isnt eight gauge god awful to try to push into your terminals. In my opinion id go with 10 gauge or 12 gauge. There is no reason to have to use that thick of wire cause it will only be a huge pain in the ass. Unless you have an adapter for your sub to handle the eight gauge then i guess it would be just fine.
im currently getting my subs rebuilt and putting on direct leads to put the 8gage.. the terminals being too small crossed my mind. thanks for the insite!Isnt eight gauge god awful to try to push into your terminals. In my opinion id go with 10 gauge or 12 gauge. There is no reason to have to use that thick of wire cause it will only be a huge pain in the ass. Unless you have an adapter for your sub to handle the eight gauge then i guess it would be just fine.
do you know what the strand count on the stinger is???No problem! :hello: That Knu-Karma looks nice, but $1.65/ftI would go with the Stinger Pro for $0.65/ft :thumbsup:
FYI that stinger is power cable. As in it doesn't have 2 seperate connections but its 665 strandsdo you know what the strand count on the stinger is???
yes i know this but im doing spl and i need the least resistance that i can get... power wire or speaker wire its ok with me as long as its 8g high strandFYI that stinger is power cable. As in it doesn't have 2 seperate connections but its 665 strands
It's not as tough as some may think. Have you ever ran 4-5k to a woofer? I don't know about you but I'd rather not have that kind of power going through 10 or 12 gauge wire. He's on the right track and from what I understand, running bigger wire also helps to keep down on impedance rise if it's a problem.Isnt eight gauge god awful to try to push into your terminals. In my opinion id go with 10 gauge or 12 gauge. There is no reason to have to use that thick of wire cause it will only be a huge pain in the ass. Unless you have an adapter for your sub to handle the eight gauge then i guess it would be just fine.
Yeah that doesn't matter at all...copper is copper. It is single strand, but I'd imagine it would work out better for him in this instance since he is going to be tapping on to direct leads. They will both work identically as a conductor.FYI that stinger is power cable. As in it doesn't have 2 seperate connections but its 665 strands
Strand count is important. Higher the strand count = less resistance so in turn, better conductivity. It is the same thing as doing certain things throughout the rest of the build to gain every little bit you can i.e. suretape, resin, deadener, OFC cable, etc, etc, etc. As a competitor, would you agree with this now that it is put in that perspective? I am not trying to be combatant, more or less help OP understand that he is on the right track with looking for a high strand count 8awg conductor.It's not as tough as some may think. Have you ever ran 4-5k to a woofer? I don't know about you but I'd rather not have that kind of power going through 10 or 12 gauge wire. He's on the right track and from what I understand, running bigger wire also helps to keep down on impedance rise if it's a problem.
OP, if it were me and I had the cash, I'd go with the Knu but to be honest I don't think it'll make that much of a difference as long as you use true 8ga wire. In two competition cars we had this year that won at finals in mod 0-1000 and trunk 1001+, neither of them had special, expensive, high strand count wire. It was some cheap wire that appeared to be true 8ga and it worked just fine. Unless you just want to say you have this many strands in your 8ga then I think just about anything will work on your setup. It's up to you though man, if you got the cash, go for it!:thumbsup:
Ahh I gotcha...good call. I can see it now, he orders a certain amount and then realizes it is only a single conductor and has to go back and order more because we didn't clarify :rofl: :thumbsup:Yeah, I know it doesn't matter. I use 8 gauge stinger HPM speaker wire for my subs but I just wanted to point tha out in case he was looking for "speaker" wire. I know some people are picky and want both strands together.
