1 - 12 of 12 Posts
151.8 and climbing :D
1. Product: audioque 2200.1
2. Specs: ModelAQ2200DDigital Monoblock 1 ohm stableInput Sensitivity0.2v-8vVariable Low Pass Filter20Hz-200Hz @ 24dB/OctSubsonic Filter10Hz-50Hz @ 24dB/OctOutput Master / Input Slave, 2 amps linkable connectionRemote Level ControlClipping Display LedSignal to Noise Ratio90dBExternal Fuse Rating200 Amps, 400 Amps LinkedTested Voltage14.4V4 ohm power @ 12V @ 1% THD500x 11 ohm power2200 x 11 ohm Power @ 16V2500 x 12 ohm Linked Power @ 14.4V @ 1% THD4400 x 1Dimensions17.71"(L)x9.27"(W)x2.35"(H)
Great condition, it has a few minor scratches and the remote screw hole is stripped out alittle. If u angle the screw it will tighten. (luckily its only the remote)
It will come in original packaging w/ bass knob but the bass knob doesnt work (the clipping indicator and power light do however)
4. What you are looking for: :
Id like to trade this plus cash for something around 3500-4k watts. If i dont find something soon, im just gonna buy another aq and strap em.
5. Pictures of your item for trade:
Dates not up to date, but im not required to do it anyway.
sell outright?
1 - 12 of 12 Posts
