1 - 9 of 9 Posts
1. Product: 1 pair of DD 2518's & Memphis Mojo 2500.1
2. Specs: Subs: dual 2 ohm, 800 rms each (underrated)
Amp: 2500 watts @ 1ohm
3. Description/Condition: Sub: 9/10 just cause they have been mounted and tested but not used.
Amp: 9/10 only cause I used it for 1 week at 2 ohms on plenty of electrical. I should give it a 10/10 cause it's almost flawless.
4. What you are looking for: CT sounds amp and sub package. Would really like a 1400.1D or bigger and a pair of meso 12's (if there even available yet, I'm not sure) if not the strato's would be fine. I want 12's but would entertain other sized woofers.
I'm willing to take a loss on my equipment in order to join the ct sounds bandwagon.
Also, I travel almost every day from Memphis, tn. To Harrisburg, pa. So if u live somewere along that path of I-40 thru Tennessee or I-81 thru virginia and up to Harrisburg I could save a lot of shipping cost and meet someone as long as they could meet at a certain time.
5. Pictures of your item for trade:
Also have matching Memphis m-class multi channel amps
I just noticed while editing my ad that I put DD 9518 as the model of subs. That is completely wrong. They are the 2518's and I'm sorry for that. Idk what I was thinking. Guess I need to delete this thread and start over.
1 - 9 of 9 Posts
