1 - 2 of 9,084 Posts
Hey T, after doing a lot of research for my build, which is aimed more towards "feeling" the music because I'm deaf, I learned from a dude at the local shop that if I had 16 SVC 4ohm drivers wired in series/parallel I could achieve a final load of ~4 ohms. Now it's been a while since I did the math to figure out the wiring I would do, so if possible, through a PM is fine, could you explain how to wire them, and maybe a little education on wiring more than 4 drivers per channel?
Sent from my iPhone using Tapatalk
