The 250A fuse-
Be having the background with Taramp's, first thing that comes to mind is, well simply, they are accounting for it to be wired at 1ohm so the fuse will not pop..
Well, i have 2 problems here-
1, the 5k and 7k both use the same size fuse. This is a curious question there..
2- the biggest problem i have is it's rated for 5,100w @2ohm 12.6v.. yes 12.6v. Over 6,000w at 14.4v
I've done plenty of playing around with fusing in my day as MECA was only close organization around my area.
For continued currect draw in a daily environment, i've experienced the following-
Using custom fuse blocks for more adequate surface area, fusing does not like to be subjected to a continuous averaged draw of around 50-70% more the rating of the fuse.
In my experience, the fuse would never pop, it would slowly discolor overtime creating resistance.
Resistance=heat and there is no protection around that fuse if heat creates smoke.. and then enough heat to start burning something.
At the lowest current draw, the LEAST i can possibly create an example is the following-
5,100w @12.6v based on 90% efficiency(for example)-
449A of current draw minimum and this is simply just using batteries.. Just adequate batteries, no alternator required in this example.
250A fuse results in a draw 80% more than the rating.
Now, one of 2 things can only happen.
1- the fuse will pop
2- the fuse will not pop
If you have enough batteries, it is assumed to say that could be dangerous for the integrity of the amplifier.
Now, if i'm not mistaken, Banda-USA gives the customer the option to allow to use something they have made to relocate the fuse outside the amplifier.
While this is great idea, especially could upgrade size... Is upgrading the size safe?
All these questions i have is something you guys should find out!
FYI- Taramp's HD8000 is rated for following-
5,250w @2ohms
Manual suggests a 430A fuse, so let's say 450A.
We have ONLY and i mean ONLY ever had a necessity to recommend a user increase their fusing size because their electrical system is so good for the amplifier, that they were pulling close to 600A and popping it so we suggested a 550A and has been fine.
So, in this example, we fuse for the load and application it is used for without failure.
Perhaps Banda's fusing is literally the same way, with the exception that according to calculations, they do not want or expect large battery bank.
While speculation needs to be tested, it does need to be tested.
I'm sure these amplifiers do their rated power fine. It's the consistent output that has me curious on a GOOD electrical system.
We all know it is not designed for a true 1ohm load which is fine.
But a true 2ohm load for several minutes would need to be tested or perhaps longer and then inspect fusing.
Answers to these questions would be great!
