DLS Ultimate A3 Amplifier Twin Mono
2.9K views 4 replies 4 participants last post by  splvictim20
#1 ·
$300 shipped
Amp is scuffed and has holes drilled on the bottom for fans. I bought this amp like this but don't need two. I've got 6 DLS amps and need to part with a few. I've got REFs off other forums as well as 100% ebay.
  • RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
  • Mode : AB
  • Number of channels : 2
  • Output power in 4 ohm : 2 x 150 watt
  • Output power in 2 ohm : 2 x 270 Watt
  • Output power in 1 ohm : 2 x 425 Watt
  • Output power in 4 ohm bridge mode : 550 Watt
  • Output power in 2 ohm bridge mode : 870 Watt
  • Output power in 1 ohm bridge mode : 1200 watt
  • S / N ratio, A-weighted : > 100 dB
  • Damping factor : > 200
  • Input impedance : > 10 kohm
  • Input sensitivity, variable : 0,2 - 7 V
  • Filter, highpass, variable : 20 - 200 Hz
  • Filter lowpass, variable : 50-125 Hz
  • Terminal for external cooling fan : Yes
  • Double DC-inputs : Yes
  • Phase shift button : Yes
  • Current draw, idle : 1,1 A
  • Current draw, maximum : 140 A
  • Dimensions W x D x H : 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
#4 ·
Well I've got nothing to hide and am open to offers. Good price for the quality and power... I'm just going for a more bling factor and bought a new A3 .. trust me you guys don't want to spend that much haha.
#5 ·
Bump it up for a good guy & my old amp.
