Rockford Fosgate P200-2
595 views 1 reply 1 participant last post by  Afficionado
#1 ·
A classic Rockford Fosgate p200-2 amplifier.
  • 2-channel car amplifier
  • 50 watts RMS x 2 at 4 ohms (100 watts RMS x 2 at 2 ohms)
  • 200 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
  • CEA-2006 compliant
  • Dynamic Thermal Management cooling system
  • variable high- and low-pass filters (50-500 Hz, 12 dB/octave)
  • variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12,000 Hz)
  • optional wired remote bass/treble boost
  • Class-AB amplifier design
  • MOSFET power and output stages
  • preamp inputs
  • 8-gauge power and ground leads and a 40-amp fuse recommended — wiring and hardware not included with amplifier
  • no on-board fuses — when installing multiple amps in a system, an additional 40-amp in-line fuse between the distribution block and the amplifier is recommended
  • 8-7/8"W x 2-1/4"H x 7-9/16"D
This thing looks like death. it just looks awful...like it was beaten and stomped on....but like all Rockford gear does, it hangs on and still delivers the power!
$50 shipped.
Save
You have insufficient privileges to reply here.
