41 - 60 of 84 Posts
Surprised no one else has mentioned it yet. The huge fact of efficiency comes into play. I have seen a lot of amps efficiency drop to 65-75% at low impedance. Where as at higher impedance many amps go up to as high as 90%. To some this means nothing but to others it is important.
The real importance to me lies in the amperage/voltage flowing through the coil. Lets say I want to put 1000w through a coil. I could at .5ohm (44a/22v) or at 2ohms (22a/44v). Now at 2ohms I have 1/2 the current going through the voicecoil then I would with .5ohm. This results in less heat, which means less chance of hitting the thermal limits of the subwoofer. Some people are asking, well why dont more people do this? Well simple answer is people enjoy cheap dirty power because well it does enough to get the job done.
I FINALLY realized this!!!! I love bigger amps ran at higher ohm now bc of the efficiency difference. :)
not to mention the ability to play more "flat" depending on impedance curves. every note has a different power, if your box is designed right you will play more flat if you wire higher or lower depending how its designed. 1x rise at 20hz and a 5x rise at 40 hz but your peak is 40 hz, so wire higher youll get less power at 40hz thus toning down the volume and since you get hardly any rise youll have the power needed at 20hz to get MORE output. if that doesn't make sense, I apologize. I don't have much more time than this to explain on break lol
My question is this...
IF you wire higher and try to get more volume (Dbs) at say 40Hz, you WILL push the system harder to get the desired volume at that 40hz... and that could result in pushing the amps too hard.. with the rise up to say 3 ohms and cause clipping and excessive current draw, because the amps are rated at and will only be able to produce lower power at a higher ohm load.
If wiring lower gets you the desired output (Dbs) at that same 40hz, BUT running the system around half as hard... This will result in less heat and less current draw due to the fact that you only need to push everything HALF as hard to get the same results...(and you should have a little extra power left over to use at your "discretion").
At least this has been my experience with wiring down.
I DO agree that the responce WILL be much flatter running at a higher impedence, and most likely sound a little better too.
Depends on what your looking for .. Music 1 ohm or .7 spl .5 or .35 like stated as impedience drops so does clarity I can hear a difference
I run at .5 and .35 daily. I don't worry about the added current being sent to the subwoofers because it was a lot easier and cheaper to get a heftier coil in my subs than it is to pack the back of my limited space with 2 or 3 times as many huge amps.
But I'm also running a bank of 5 d3100s for a single Saz1500 now too
I've always run at .5 and 1. I like .5 much more as I have the electrical to back it up.
i totally agree i always plan to run a amp below rated impedance..
well except for the ultra picky ones that fry or protect right away ( like a kicker zx1500 tried running it at 1ohm..it played for awhile lol)
Imo. Saying you can hear the difference between 1 ohm and .5 is about as realistic as saying you can hear a 1 db change in a sub system. It's psychological. If you didn't know it changed you wouldn't hear a difference. The change in damping factor etc.. is not significant enough to hear a difference unless you are superhuman.
i have a 250amp MCR HO ALT w pos and neg 1/0 AT cca ran to my crescendo 3kwp @ .5ohms on my SKAR ZVX15d1 and my electrical is fine....12.4 lowest i seen...and i played full tilt yesterday for 45+ min and i couldnt get the amp or the sub even WARM
goin down the hiway i can barly push it under 13v....maybe 12.5 on sum clipped songs on certain notes
and i actually see a difference in my system from when i had 2 sa15s on the same amp wired @ 1ohm.....with the sa15s i could drop to the high 11s on certain songs.....im sure theres other factors in my cituation but i can tell my voltage holds better w/o a doubt running this 3kwp @ .5ohm
41 - 60 of 84 Posts
